mushymelon
This may be a stupid question but can I run a 110v ac chainsaw directly on dc.
I want to clean up some trails.
Thanks
Mushy
Thanks
Mushy
dnmun said:you can figure out the polarity by opening it up and finding the diode. that will tell you the polarity you need to use to make it run forwards.
you wanna bypass that diode in any case. actually just rewire it to that point past the diode and use an external switch.
you could even use a power board from a BMS and turn on the mosfets with a small 9V battery and then put the small switch in the small battery power lead so it would turn off the mosfets that are carrying the current for the power saw. put the 9V battery negative to the negative B- lead from the 24S pack so it sees the proper ground.
but that is all very dangerous because of how fast the saw can do personal damage in a short period of time.
do not expect any switch to turn off the power. put andersons or other connectors in the battery lead so it can be disconnected in any case of failure. it may put out more power than you expect also.
Dauntless said:I'm told my lawnmower is essentially ready for battery power with an AC transformer and would be an easy conversion, perhaps your chainsaw is the same.
I do think your options for a battery chainsaw are too good for you to bother with this.
http://www.lowes.com/pd_506890-95404-KC ... facetInfo=
http://www.lowes.com/pd_216440-70-CCS81 ... facetInfo=
major said:I don't understand the comment about the lawnmower running on a battery with a transformer :?
Dauntless said:I have the Remington version of this, I'm told it's the same factory in China, etc.
http://arborist101.com/poulan-pln3516f/
My feeling is it's probably no more powerful than that Craftsman, I wouldn't be surprised if it was the same motor. Why would the battery be better connected to the AC unit? I see no logic in that.
mushymelon said:I have a gas chainsaw.
I also have the electric too.
Noise is the issue.
dnmun said:mushymelon said:I have a gas chainsaw.
Noise is the issue.
for a simple contactor, why not just have two copper leaves, or just one, that you would just push down with the thumb to make contact and then it would open when you let up. so it would have to be springy copper. so it might get hot. make it wide enuff to handle the current so it wouldn't burn your thumb, and give you an excuse to rest the battery when the contactor gets too hot to push down, hehe.
