Sorry for the newbie question, but I am experimenting with 4S lithium 18650's and I hope to charge them from an unregulated 12V automobile accessory socket.
4.2V x 4S = 16.8V, so the 14V socket output will never overcharge the pack. The pack will end up with a "half charge" when using a car socket (roughly 3.5V per cell) but I do have an RC charger that can provide 16.8V when desired. There is no BMS for this particular experiment.
I understand that 4S LiFePO4 is common for 12V, and also 3S 18650-cells, but that will be for another discussion elsewhere. This pack is lithium-NCM in the 18650 format of cells, 4S
I assume I must add a resistor to limit current. Should the resistor be located on the positive/red lead, or the negative/black?
Should I put a resistor in both?
