JoshKeller
100 µW
Hey guys, I was referred here by a Facebook group. I have a Chinese "1000"w geared hub ebike that originally came with a 17a controller. I've replaced the controller with a 37a max and s866 screen to 22 amps and it did provide more power. I still can only get 13a max from it. I've tried two batteries - one 48v 13 ah, and a 52v 17.5 ah - the 17.5 ah claims to have a 30a bms. Any suggestions why it's only drawing 13 amps max? Is it possible the controller is 13amp nominal/38 peak? I use this bike for hunting and want to get it running 100%.
Here is the controller - https://www.amazon.com/dp/B081LCWL5Z/ref=cm_sw_r_cp_apa_glt_fabc_QERYNJ2Y4MN16DAB9GHT?_encoding=UTF8&psc=1
This is the sound it makes when it hits 13 amps. It's quiet as can be once the amp draw drops below 11
https://youtu.be/hboMIZLuc8Y
