MikeSSS
Wife's Townie is 7 speed freewheel hub in the rear 135mm dropout, the frame is aluminum.
The Bafang G310 rear hubmotor has OLD spacing of 138mm, 138mm is about 2.2% wider than 135mm.
I'm thinking this small percentage of spreading will not cause problems for the aluminum frame, especially since it won't be spread and unspread very many times. It won't have a lot of spreading and unspreading cycles.
Typical use for this bike will be around 100 miles a year, expected use life is about 8 years.
What do you think?
Thanks, Mike S
What do you think?
Thanks, Mike S
