liveforphysics
100 TW
circuit said:What's the Kv rating and inductivity of this motor?recumpence said:Here are the specs;
Can length--- 4.5 inches
Can diameter--- 3.75 inches
Shaft diameter--- 1/2 inch (keyway shafts will be used)
Expected efficiency--- 94% (more on this later)
Continuous power--- 14kw
Burst power--- 25kw
Weight--- Under 7 pounds (expected)
Oh, I expect the sensorless motor to be $950
Matt
Normally you can get your Astro motor in any KV you want, which would mean any resistance and inductance that you needed.
