Doctorbass
Couples of drag racing guys contacted me about making 16V battery for them after they watched couples of my youtube videos.
I know they already exist.. some made of A123 cells some with RC lifepo4 cells... etc...
For those who already know them, My question is : do you know if there is any LVC protectin inside?. I mean a battery thatc an give 50A per cylinder will need like 4-500A during the start of the engine.. so it must have a contactor or something else? to prevent the battery from overdischarging?
Also.. are these guys use an alternator?.. if so i guess they need to tune it to 18.5V for for cahrging the battery fully?
After some calculations these guys said they would need to power everything in the drag car for around 25 minutes.. for an entire drag racing day... they often dont use any alternator and preffer recahrging the battery with an external charger. Wich is good and easyer for me to build. The entire system including head light, motor fan and fuel pump and ECU require max 50A..
So 50A during 25 minutes is 20Ah.
So building a battery of 23Ah would be the minimum.
23Ah of A123 cells is 10p cells.
To make 16V i would use 5s cells wich is 3.3 x 5 = 16.5V nominal wich is perfect for their needs and probably 18V full cahrge at 3.6V per cell
So a battery made of 5s10p is 50 cells and each cell weight 70g so the entire cells in the battery would weight 3.5kg for 370Wh
The max continuous current woudl be 70A x 10 = 700A and the burst current would be 1430A for 10 sec wich would be able to fry many starter!
So.. for the LVC cut.. i guess that maybe an EV200 tyco contactor combined with a little BMS circuit that control the contactor LVC thru a transistor and 5 shunt to balance the cells would be ok...
Doc
Doc
