docware said:Regarding fixing the triangle, I believe you are intelligent enough to find your way to fix the pack. You know the possibilities in shops around you, you will know the plastic battery pack details, not me, .......
docware said:You are right, use anything what can help absorb the vibration from the ride.
13s9p LG MJ1 is best choice for you.
The problem with a triangle bag is that you can cut it open without any special tools. That's why I want a hard cased battery pack with a possibility to securely mount it against thieves. The only triangle pack that checks those things is the UPP pack.docware said:As I am not familiar with UPPBATTERY, here is another posibility from EM3ev : triangle 14s9p 30Q.
https://em3ev.com/shop/50v-14s9p-large-triangle-pack/
Pizzabroodje said:The problem with a triangle bag is that you can cut it open without any special tools. That's why I want a hard cased battery pack with a possibility to securely mount it against thieves. The only triangle pack that checks those things is the UPP pack.docware said:As I am not familiar with UPPBATTERY, here is another posibility from EM3ev : triangle 14s9p 30Q.
I'll ask them to send a picture of the inside and there opinion on the matter.
This is the pack in question: https://www.aliexpress.com/item/US-EU-No-Tax-52Volt-Triangle-case-Electric-Bike-Battery-52V-28Ah-ebike-Lithium-ion-battery/32914588998.html
999zip999 said:If someone is going to steal you battery they will just steal your bike with rolling wheels stick it in a van and drive off. if they see the bike parked for 2 hours every Wednesday and get it then.
docware said:Pizzabroodje, regarding the secure metal straps, do you think that this
is expensive special tool ?
Well, the plastic case is really nice, i like it. Really. Just I would never buy Li-ion cells or battery from not proved e-shop. I would prefer to buy battery from company like Em3ev because of their good reputation. The possibility to check individual cells group voltage through Smart BMS/Bluetooth is also interesting.
But you can try it. In any case, you at least obtain good-looking durable plastic shell for new set of cells.
999zip999 said:Where do you plan on leaving your bike when not in use are you going to school you go to work 5 days a week and park your bike in the same spot everyday. Thieves look for patterns are there likes stealing at a circus or a concert. They like to steal ebikes at events these are people who do not live next door these are people who are going to take your bike and take it somewhere else far away. Best to get a GPS tracker.
The thing is that they don't have the MJ1 one in stock right now so it would have to be custom made. I can probably get 10% off the battery, but not if it's custom.docware said:I don´t expect huge price impact of MJ1 on the total price. 9p and MJ1 or 30Q should be your choice.
Hopefuly you slightly drop your keen effort to kill your battery by traveling high speed .
If you assume leaving the bike outside, you have to look for shade, because temperatures at direct sun warm up the battery and significantly shorten life time.
I don't want to be carrying a 6+ kg battery around everywhere I go as that is very inconvenient. I'd have to carry it from class to class for example, or when leaving my bike somewhere and continuing on foot.Philaphlous said:Why can't you bring your battery with you? Where do you go/work? Can you really not take it with you? You're explaining all these elaborate plans to secure the battery and the easiest of them all is to just bring it with you. I park my bike at a dc metro station and I always bring my battery with me. Now thankfully I feel safe enough to keep it at my desk at work and my coworkers are cool wit it. I use two lock. A u lock with cable and a boron carbide masterlock on the rear tire/spokes to frame. Seems secure enough and I've never had an issue for the 9 months I've been doing it. I'll probably switch up my ride this year to not park at the metro anymore once I've got my new battery built..
Why dont you figure a lock to put between each wire at the connector? If you could do that and have like a little xt90 extension and put a lock between the two a thief would have to literally cut at least one of the wires and the lock to get it out and likely ruin the battery in the process. Best part is you wouldn't have to touch it when you leave or get to your bike since it won't interfere with your ride. I use a zip tie and whereas it's easy to cut. Someone will likely ruin the battery by cutting the wire accidentally would be my guess... Either that or short out the connectors and get a freaking huge spark...I'd think that'd be a decent deterrent.
Joachim said:Long story for a simpel battery je maakt het je zelf wel erg lastig
