I don't have as much experience as you do so...
but I don't think they that the current which travels serial from cell to cell is not going to take the long way around and go from the cell over to half way between the next cell in it's P=group then across the copper wire back to the 0.15x7mm strip then to next cell, I think it would be better if solder the wire on top of the nickel strip or well another strip on top. The current will take the most direct path, or should I say the path of least resistance, how ever as heat goes up so does resistance and if the nickel strips heats up high enough and the resistance goes high enough it will then move over to the wire you suggested between cells which is a longer path but a lower resistance. Is my position correct in your opinion.
Better, but yes I know to late, would be to use 0.2 which give 9A on a 7mm strip or better yet use a 0.15 plate and get 18A (18650s are 18mm wide, 1A per 1mm width on a 0.15 thick strip, 18A) there P-group cell, or even 0.2mm plate which is good for 24A per cell (18650s are 18mm wide, 1.33A per 1mm width on a 0.2 thick strip, 24A).
