Gazza
- Joined
- Feb 16, 2017
- Messages
- 24
Hello,
I am planning to assemble a Solar Battery from New 18650 cells.
Panasonic, Sonyo or LG seem to be the leading, verifiable brands.
When I ask for quotes I am bombarded with all the newest High Discharge Cells.
Unlike the Majority of requirements for Cars, Bikes and lights,
my requirement is for a Max Constant Current <= 1/12th of the Cell Capacity.
So these are some Lower Discharge types I have stumbled upon,
or followed up after suggestion.
LG INR18650F1L(Rated 3350mAh) (1.5C Max 4.875A)
*PANAS0NIC NCR18650BE (Rated 3200mAh) (Typical 3180mAh) (1.1C Max 3.63A)
*PANAS0NIC NCR18650G(Rated 3400mAh) (Typical 3550mAh) (1.3C Max 4.87A)
*PANAS0NIC NCR18650 (Rated 2700mAh) (Typical 2900mAh) (2C Max 5.8A)
*PANAS0NIC NCR18650D (Rated 2700mAh) (Typical 2550mAh) (2C Max 5.1A)
*PANAS0NIC NCR18650F (Rated 2700mAh) (Typical 2900mAh) (2C Max 5.8A)
*PANAS0NIC NCR18650A (Rated 2900mAh) (Typical 3070mAh) (2C Max 6.14A)
*PANAS0NIC NCR18650B (Rated 3200mAh) (Typical 3350mAh) (2C Max 6.7A)
*PANAS0NIC NCR18650BF (Rated 3200mAh) (Typical 3350mAh) (2C Max 6.7A)
*PANAS0NIC NCR18650E (Rated 2100mAh) (Typical 2250mAh) (3C Max 6.75A)
*PANAS0NIC NCR18650BL . . . . . . . . . . . . . . (Typical 3350mAh) (2C Max 7A)
Looking for Common Cells that might be cheap for +500 and +1000 pieces.
Any suggestions for other Commonly Available, High Quality Cells that might be Suitable for Lower Continuous Current?
Thanks,
Gazza
Thanks,
Gazza
