SafeDiscDancing said:Great build ...
soyachips said:Thanks, it's been quite a journey but heaps of fun.
SafeDiscDancing said:I looked up those battery cells on Alibaba and they say they are of the LiFePO4 type but then when listing maximum charge voltage say 4.2 volts.
Isn't the normal maximum for LiFePO4 more like 3.6 volts?
Which value are you using?
That value is in order to create what is usually called a "throttle curve" it varies how much power the motor will deliver in relation with the throttle position. You can have a linear "curve" when it is at 50, exponential when it is over 50 and logarithmic when it is under 50.
soyachips said:Yes LiFePO4 max is 3.65V. I guess the same cell boxes are used for different chemistries.
kuoppis said:Those battery boxes are looking really nice and clean! One thing i would change is the fuse, i dont think ANL fuses are meant for higher voltages? I know a short between those terminals is rare and there is also the BMS protecting but cant be too safe :wink: Take a look on Bussmann LMT fuses they should do the trick. But otherwise very nice and professional looking battery boxes!
kuoppis said:Too bad that reading SOC data from ANT did not work that is something i wanted also. What are you using to measure remaining capacity on that meter? Voltage?
soyachips said:Also they claim to be CATL cells which would be amazing if they are but not sure. So far they seem to be performing well.
Would like to know where to get the bussbar u used? thanks .OK so once again its been way too long between posts so I'll add some photos to try and fill the gap up to where the project is now!
After sorting out the testing I used a fantastic 2p busbar kit made by Chris Jones which made assembly really easy. The panels for the box were cut on a friends CNC router and welded by someone I found on Gumtree (not there yet with my welding skills) and the terminals were made with copper bar and a 3D printed bracket.
