userperson1748
10 µW
- Joined
- Apr 30, 2019
- Messages
- 6
deleted
No, it doesn't.flat tire said:Attaching as a friction drive automatically gives you a gigantic reduction gear ratio,
amberwolf said:No, it doesn't.flat tire said:Attaching as a friction drive automatically gives you a gigantic reduction gear ratio,
It's not intuitive, but using a motor to drive a tire does not change the speed/torque of the motor at all. It is exactly as if you were driving the motor on the ground surface.
If you are willing to do some reading, and playing wiht systems in a simulator to get an idea of what different "gearing" (wheel size with a hubmotor, etc) will do, you can go to http://ebikes.ca/simulator, and read the whole page and setup various systems in there, and change just the wheel size, then change the slope, and see how the wheel size affects one particular system (vs the same with a different wheel size); you can A/B them and visually see the differences in power/torque/heat/etc.timl132 said:I have a question for you though, you say "don't end up with the wrong gearing", how accurate does the gearing have to be, what target speed do I built the gearing for?(I can make to motor thicker or add a gear if needed to adjust target gear ratio and speed)
There's a lot of reasons; if you want the details you can look up the various threads about Voltage vs Current (sometimes stated as Speed vs Torque).Also, I have a question for all other peoples: Why do e-bikes always have high voltages? Why are there no 24v 1500w e-bike kits/motors? Does higher voltage allow for lower speed motors or something?
