bobc
OK, I've been running this today; no disasters or burnt fingers; it's good but too slow.... originally designed for a much smaller motor (which therefore revved a lot faster) it maxxes out at just 17mph in the high gear, so almost legal ;^)
So I need to go for a rather smaller rear sprocket (that one's 100 teeth...)
OK the interesting bit: the reversing gearbox... What can I say - it seems to work exactly as expected, and, also as expected, it's a bit on the noisy side. The steel gears are in mesh all the time (even when drive is via the belt). Once you're up at 17mph there is enough wind and other noise to make the motor/gear noise seem not too bad.
The little (3mm pitch,9mm wide) belt skips a bit when full throttle is applied - I don't think it's going to last long: I'll start making the 5mm pitch components.
What this really means is that I am going to have to finish off the lipo charger/equaliser I was making.... ;^)
