2025 Aniioki AQ177 Dual Motor Questions
4Forethought
Sonora, California USA
Just purchased an Aniioki AQ177 and have several questions that I hope one of the Endless-Sphere gurus can answer.
1.This is the AQ177 display. It appears to be a fairly standard UART but there is no information online, at least none that I've found. Many common P-codes are missing and several are locked. It's also Bluetooth equipped but I haven't found an app that will connect to it. The Aniioki A8/A9 app (and several non-Aniioki apps) sees the display but will not connect; apparently because the AQ177 is not supported.
- Can anyone ID the display manufacturer?
- If so, do you know what controller(s) it supports?
- Is there a software program and/or hardware that will access the full set of UART P-codes and perhaps unlock the locked codes?
This 4-pin connector is located in the same frame cavity as the controller. Any idea what it is used for?
Thank you all in advance for any insight or answers you can supply and sincere apologies for the noob questions.
