Hey Zappat thats awesome! I love the idea I think that would be so cool to have. Motocross bikes run rim locks and if you make enough power you will want to as well. I realy like the build though I realy want to go build that right now!
methods said:That is a bad-ass bike Pat.
I use Baby Powder to mount tough downhill tires on the rim. I then set them down and step on the tire to get it to pop in.
I am amazed that you can run a 3" tire on such a tiny rim. I run similar 3" tires on Sun Double Wides.
Good job solving the grounding issue!
I second fechters note about real brakes - if something goes wrong you could lose your brakes.
I suggest a 2x4 on a hinge right behind the seat. You can step on it to slow down
Well.. I am jealous of your build.
I am going to have to make something like that now to show you up
-methods
P.S. Anyone else who has 2WD pictures -> Post them up!
steveo said:I am waiting on my bike from to do star delta 2wd with 16" wheels!!!
i can't wait1!! here is a sneek peak of my drag bike on a shitty bike chasie...
http://www.youtube.com/watch?v=FOMFlZVPf6I - 140ish pound rider
http://www.youtube.com/watch?v=dfef7JgL240&feature=related -190lbs rider
-steveo
rgody said:Time ago a friend and I installed 2 350W hub motors in one ebike ...
Here the video :
http://www.youtube.com/watch?v=QM35qeiYYN4
And here a picture :
We use 9C motors, two 33A controllers , 1 twist thotlle , and four 12V 14AH SLA battery pack.
I remember we just conected each black (ground) , and blue (speed reference) wires of both controllers to the throttle.
Im not sure but I think we use only one controller to feed the throtlle (red cable with 4.2 V or some like that).
We didnt open the controllers.
The behavior of ebike was like light electric tractor. very powerful. Not much speed were reached due high currents that 2 motors absorbed. (more than 45A for small but heavy 14AH SLA batts)
Regards
Rodrigo
2 or maybe 3? wheel drive?methods said:That is GANGSTER
Just trying to figure out how I will get enough traction for what I want to do.
-methods
Sounds good for motor KV / wheel diameter ratios (0.60 vs 0.61).methods said:3WD
Two 10x6 9C's up front in 16" wheels
One 6x10 9C in the back in a 26" wheel?
I have the motors, controllers, and batteries.
I just need a frame.
-methods
ZapPat said:But there's one problem. The front wheels on most all trikes are one sided mounted only. Any ideas on overcoming this problem?
Can you use 2 hub drives on a Trike?
recumbent said:First of all you will have to find motors with a stub axle, which i think Renaisance cycles has for Clyte motors they sell.
Yes, I did make two ground connections directly between the two PCBs with heavy wire. Note that this was done with 6FET infinion (116's really) controllers using IR4110's, and I have since ditched these for dual 12FETs (using 60V IR3006's) and have been using these for a while now. I did not fix the grounds of the new controllers together inside the cases as I did with the 6FET ones before - I just used 8AWG wires, as short as possible and connected them together outside the cases... and the throttle stutter problem is fairly noticeable. :|methods said:IIRC Pat and found a solution to the misfire issue correct?
Didnt he just have to tie a solid ground between the two throttle grounds?
This is how I have mine setup right now, and yes it helps quite a bit with handling. But don't just play with the battery current limits, you can also play with the phase current limits without danger. Mine are setup right now like this (note that my shunts are soldered so the limits are actually a bit higher, no CA yet to confirm real currents):I think this time I am going to do something a little different.
I am going to run a much lower current limit on the front than on the back.
Maybe 20A on the front and 40A on the back.
I hope that this will improve the traction control issues.
What can I tell you, great minds think alikemethods said:You stole my phase current idea :?
New update as promissed --> I've put my first 2wd bike (dual 26" hardtail) back together after fixing up the controller pair today. I did not mount the controller PCBs together as close as previously (that time I did both end to end with two short and thick jumpers between grounds on the edge of each board - see photo posted already). This time I stacked them belly to belly each in their own cases, and there are two short 10awg wires (under one inch) runing between the same two ground spots as before. I also beefed up the power cables to 12awg instead of of the 14 I used the first time. Both positive and negative leads of the controllers are about three inches total before joining to common points just out of the controllers.methods said:Thanks for your info on the grounding issues.
Could you expand on this? Are you saying that the controller software is a bit buggy when it comes to handling a stalled condition, and that you feel this "strugling stutter" even on your single hub bike? And do you mean it's worse at low voltage and low current limits, or just that it does it no matter what settings?methods said:You know I have noticed this misfire issue with just a single motor running 44V and a 20A current limit.
There is a problem with how they handled stalling / low RPM in the software.
Wouldn't help tostino, because the problem is most likely taht the current spikes made by the stalled controller are changing the ground potential between the two controllers. That means that an analog signal common to the two of them, like the throttle, will appear to vary between controllers because of voltage difference created by the spike.tostino said:Would running a lm317 right off the battery pack to power throttle, and then just splitting the return line to both controllers work? It'd probably be pretty inefficient, because you would need to get the pack voltage under 37v for the lm317. Lotsa heat waste in resistors .
