sange said:
I have two 36V/10Ah batteries. So the choise of the batterie is already done.
I will rprobably use the same motor on for the front and back,
To set the ebike.ca simulator I have used the Q100 328rpm motor, with a.55.5V battery (to simulate the 24V motor version : 24V*37v/24v) and 15.3A controller (also to simulate the the 24V motor : 23A*37v/24v), and the bike loads are divided by 2 (‘custom frame’ and ‘custom weight’). That set gives a 53 km/hr max speed and a 8% road grade without overheating which is perfect for my usage.
motomech said:
You will never see 50 Kph(32 mph) with 2 Q100's, irregardless of what versions you use.
... expect a top speed for two 328's @ 36V to be around 40 Kph.
Motomech's top speed estimate is spot on.
Your simulator analysis for 2WD analysis is flawed which led to some bad projections. The simulator relies on intersection of the Motor Power curve (power developed not power consumed) and the Load Line - which is the power required to propel the bike at a given speed. 2WD analysis is simple for two identical motors/wheels/controllers - just locate the intersection of the Load Line and
twice the motor power curve of a single motor. Easy peasy,
Here's a quick run with a little How-To and results that illustrate motomech's estimate:
2 x Q328, 25A controller, 36v, 230lb bike+rider = 25mph (40.5kph) top speed.
Adding the extra step to align the speed cursor as indicated will allow you to play with the parameters (throttle/grade/weight/wheel size/controller rating) as per normal to see what happens to your speed, current, and overheat times.
Remember that the leftmost part of the motor power curve before the discontinuous peak is the controller limited portion under high load (typically acceleration) so from the plot above, your motors are running at only 10.3A of the controller's configured max of 25A; flat out on the level, the controller limiting does not really have an effect on top speed. Even on a 7.5% grade, the controller limiting is not in play until you get the controller limit down to 15-20A. If you experiment, you can get a rough idea of a 'safe/safer' controller size for your climbing needs (no or slow overheating - if such a setting exists). In any case, as with a single motor, heat-wise things go wrong pretty rapidly with these little motors if you climb even slightly steeper than planned.
In any case, you can see your 2x10Ah batteries are going to be running at 1C at that speed (Battery Amps per motor = 10.3). Climbing something like your 7.5% incline will send the battery amps to about double that or 2C.
So - not surprisingly - two motors substantially improve your hill climbing and acceleration, ease your overheating issues, but will do very little to buy you more speed. It looks like what you have proposed will make a nice torquey bike, but not the speedy bike that you wanted....
