mr.pibb
1 W
- Joined
- Sep 15, 2012
- Messages
- 58
Hello. I am fairly familiar working with controllers for brushed dc motors but new to brushless.
I have purchase the motenergy PMAC-SS (ME0201014201) Brushless Motor (directly replacement for the etek)
Specs found here:
http://www.electricmotorsport.com/store/ems_ev_parts_motors_pmac-ss.php
http://www.motenergy.com/me0201014201.html
Can anyone recommend a controller to use? Im looking at the Kelly because they are only around $250-300. electricmotorsport recommends a $600 Sevcon Gen4 which maxs at 180a peak and my motor is rated for 300a peak for 1 minute. They say: "These patented axial flux motors are designed to work with sinusoidal (sine wave) controllers such as the sevcon." Apprenenly it needs a Phase 8 Pole PMAC controller. There are many other controllers out there too. I just want to be sure that I will not damage my motor. Has anyone had any experience with this motor/controller configuration. Price is not a total constraint but $600 seems a little high to me. Also I would like to utilize the full 300 peak amps because I will be pulling over 1500 lbs with riders batteries and cargo. Im going to need it to get the quad started rolling. After I get moving I only plan to go maybe 20-30 mph max.
I got the motor for a good price, so there may have been better options for me out there but this is what I went with. I will be using it to power my zem quadracycle. My hope is that I can find a relatively cheap bevel gearbox to be able to mount it to my driveshaft axel. I am tight on space and $$ so I may end up going chain driven but it would be so much cooler to use a gearbox
THANKS FOR YOUR INPUT GUYS! If anyone is in the fort Lauderdale area I welcome you for a ride once I get it going!
Specs found here:
