Phaserunner replace PMAC controller?
goatman
🏍️ Giga poster
Surrey, B.C.
im looking at a motenergy motor and wondering why a Phaserunner cant work?
heres the description
Designed for long life. No brush maintenance. The motor has peak efficiency of 90% at voltages between 24 to 72 VDC. Continuous current of 90 amps at 48 VDC. This is a 3-phase, Y-connected Permanent Magnet Synchronous Motor with an axial air gap.
Commutation is accomplished with an internal Hall Cell assembly, connected to the 6-pin external wire harness.
This Brushless motor requires a 3 Phase 8 Pole PMAC controller.
These patented axial flux motors are designed to work with sinusoidal (sine wave) controllers such as the Sevcon Gen4.
then you have ES member j bjork converting an alternator to pmac using a nucular controller
https://endless-sphere.com/forums/viewtopic.php?f=30&t=110777&p=1626533&hilit=nucular+pmac#p1626980
edit- never mind, had a , DUH, moment
