john61ct said:But, the use of a temp sensor so CAv3 can limit the power supplied as overtemp condition is approached
can allow you to calibrate in order to avoid the melting part
right?
What do you mean? Do read the temperature?john61ct said:What is the third way?
MadRhino said:FUN
That is what happens. Still, the real fun begins around 10kw.
Will it fry?
Not right away.
Not if you are conscious of the limits. Temp limit, time limit. Components limits.
We’ve been doing this for more than a decade. Over powering electric motors is common and easy. Your cheap 1000w kit can do 50 mph and accelerate cars, still lasting pretty long. You need controller mods (or a bigger controller), bigger wires and connectors, high C rate batteries... and a better bike eventually: stiffer frame, better brakes, suspension, wheel building...
Now we have choice of bigger motors, that we can over power even higher, longer, safer.
lithail said:What do you mean? Do read the temperature?john61ct said:What is the third way?
Like most of us building performance, HobbyKing.comlithail said:MadRhino said:FUN
Will it fry?
Not right away.
Mad rhino I notice you are in Canada . Where do you get your batteries?
MadRhino said:Like most of us building performance, HobbyKing.comlithail said:MadRhino said:FUN
Will it fry?
Not right away.
RC lipo can also be purchased direct from manufacturers. Yet Hobby King has experience shipping fast and reliably. First learn about RC lipo, charging, monitoring, maintenance and safety.
999zip999 said:This is a geared motor ? If so when over bolted they get fast and they get hot and sometimes just melt the plastic gears before something else. A cheap DD 500watt motor is better. But what is needed is 3,000 watt muxus or the em3ev one with Moto rim
markz said:999zip999 said:~ast and they get hot and sometimes just melt the plasti~
~ or 3kw qs, or a 1500W leaf if that 3kw is much less of the time, ~
999zip999 said:This is a geared motor ? If so when over volted they get fast and they get hot and sometimes just melt the plastic gears before something else. A cheap DD 500watt motor is better. But what is needed is 3,000 watt muxus or the em3ev one with Moto rim
