fabieville
- Joined
- Jul 15, 2012
- Messages
- 114
Please view the link below and tell me:
what would be the estimated max speed I can get operating this kit on a 24v 30ah lithium-ion battery on a flat terrain with minimal wind on a 26" bicycle with a 160lbs rider?
Also what would be the est. cruising mph on a flat terrain from the same 24v 30ah battery?
Here is the link:
http://www.ebay.com/itm/E-Bike-Mid-Crank-3000Watts-24V-72V-Brushless-Kit-With-OR-Without-Battery-/161801063207?ssPageName=ADME:X:AAQ:US:1123
Here is the specs:
Specifications:
system power : 1800-3000 wats
working voltages : 24V-72V
working current: 20A- 125A
max speed - 100 km/h , 65 mp/h at 48V
controller size: 8x15x4 cms , have 3 speed function and cruise control function.
motor is bruhsless geared
motor weight: 4 kg's
Motor size 130x130x165mm
rpm: 600rpm
torque 100Nm
chainwheel 44T 44T 32T
crank set: ISIS
BB: ISIS
gear reduction: 5:1
the kit is waterproofed, low noise , no over heat, high efficency, high torque.
Here is the link:
Here is the specs:
Specifications:
rpm: 600rpm
torque 100Nm
crank set: ISIS
BB: ISIS
gear reduction: 5:1
