Hey,
I have the Bafang 500w, 36v mid-drive unit with a dolphin battery mounted on the downtube. The power cable from the battery mount is too long as it the power cable from the motor. The plan is to remove the current connectors (bullet I think) shorten the cables and 4 new bullet connectors, attach together and seal with heat-shrink. Sounds easy! Will 4mm bullet connectors like these do the job? Am I missing something?
https://www.amazon.co.uk/SODIAL-Female-Bullet-Connector-Terminals/dp/B00L316OGY/ref=sr_1_42?ie=UTF8&qid=1470158746&sr=8-42&keywords=4mm+bullet+connectors
Thanks
Thanks
