kebekua
- Joined
- Jan 18, 2016
- Messages
- 49
Fellows, please help me!
This is the third QS273 8KW I cook in no time and quite unfortunately I'm neither a chef nor a millionaire.
Using same bike, same controller (ND841800 not maxed out), same settings, same battery. First setup peaked at 42KW, 2nd at 35KW and 3rd failed immediately at 30kw.
The first motor was 16'', I changed to 17'' with a much higher tire so I took a different winding to obtain a similar resulting speed and torque.
My first QS273 8KW (323T) lasted over 5 years, 30 000KM and failed for known reasons (corrosion caused the core to expand details in thread below).
endless-sphere.com
The second motor (434T) had a set of hall sensor fail after a month, and burnt after just 5 months despite having power limited to 80% of what the previous motor handled. QS passed the motor under warranty. The new motor (434T) seemed to be working normally until I pushed it a bit. I popped one wheelie and that was it. The temperature sensor was always connected and controller limit set to 120C. Readings never exceeded 128C. Not RPM related, never went much over 100KMH (800RPM).
I'm really puzzled at what could be the problem. Could it be the controller? Is there a way to test it without risking to cook another motor?
The different windings could explain part of the problem, the 434T has 48 strains instead of 58 for the 323T and the coils are 33% longer. That means roughly 60% more resistance, and more heat, for the 434T. But that doesn't explain why the second 434T burnt almost instantly with less power than the previous one.
Rewinding a QS 273 motor
Hello everyone, A good friend of mine unfortunately fried his motor recently. It looks like one of the phase partially melted down. He dropped the motor off to my place yesterday and now I'm trying to see if I can rewire it. That would be my first time attempting this task, so I thought I'd...
