Drunkskunk
RayB said:oh sorry, I did not see Sacmans reply. Thanks, now that makes sense. I do have the hose clamp but just had not put it on yet. So, I moved the torque arm to be mounted in back of the fork and attached with the clamp. To get around the fender mount problem I just used a plastic zip tie to secure it. Here is the final install pic.
i would try to flip that bottom piece of torque arm over and see if it could be made to align with the fender mount hole. that would be far stronger than a hose clamp. you would then be able to mount the fender stays on the same bolt as the torque arm. the longer half of the torque arm would be un needed
