Blacklisted
Love this forum.
As I've been looking for a wiki on the Currie Ezip Trailz and not found one I'll paste some info here along with my challenge.
Izip model specs http://www.currietech.com.au/Currie%20IZip%20Trailz%20AL.shtml?openmenu=5 Same except for alloy frame
My goal. I want to push my factory Ezip to 40km/h with a bare minimum of money or modification. I also peddle but I don't want the motor to stop helping at 35km/h, I can easily do that entirely with peddle power on a normal light bike. My roundtrips are generally 15 to 30kms and I use throttle to get up to speed, climb small hills and cut through head winds. The motor's squeel is tolerable especially when you're in traffic.
Albe's ebike thread is brilliant. He has pushed the bike as far as 35km/h with 36volt new battery. The defualt controller and motor seem to handle this.
http://endless-sphere.com/forums/viewtopic.php?f=6&t=2793&st=0&sk=t&sd=a&hilit=ezip
The options I'm considering and want opinions on are:
BATTERY: Instead of just a 36volt battery, I'm wondering if the controller can take just a little more, maybe 39 or 42 volts! I'd have to ask PingBattery if the cells can be arranged to deliver such voltages. http://stores.ebay.com.au/PingBattery
I've dismantled the battery box and measured it up as follows in preparation for a custom order. Two SLAs, each 151 (L) x 65 (D) x 110 (H) mm.
OR
GEARING: In combination with a 36volt setup, a slight adjustment to the gearing of the motor to the rear wheel could lift the speed a bit more. Can't remember the exact number of teeth on each sproket (I think the motor had 9 and the rear wheel 18) but what do people think about putting a sprocket on the motor with approx 3 more teeth? Will it kill it? Will I need to put more links in the chain?
OR
REPLACE MOTOR: I saw a reference to a replacement motor and controller kit which with the purchase of a 36volt PingBattery would break the bank. Maybe I would need to go to 48volts to reach my target of 40km/h. Has anyone tried this motor? It's almost as expensive as a new Crystalyte hub motor but maybe it's better. I don't know yet.
Here are the links to the specs of the original motor and the upgrade one:
http://www.cn-dcmotor.com/productShows.asp?ArticleID=192
http://www.powerpackmotors.com./Powerpack-enhanced-shipping_included.html
Any thoughts and advice on my theories to get just a bit more currie out of the Currie would be appreciated.
(You can't watch this video too many times http://www.youtube.com/watch?v=hJqVRO5zUkA)
OR
OR
