pauldo said:
It looks like that is the only way to charge individual cells,pull the pack apart
no, you do not have to take the pack apart. plug in the charger. measure the current going into the charging wire with and ammeter, then connect the negative charging wire to the B- terminal of the battery and measure the current flowing into the battery. use wire to connect the B- terminal to the C- terminal on the BMS. just bend it into a loop with the two ends exposed so you can push each end into that spot on the BMS. measure the current flowing into the battery.
