a naked 20ah pack of 80 foil pouches 16s5p, theoretical with no spaces:
width would be 76.5 * 2 millimeters = 153 mm = 6.02 inches
height would be 133.0 millimeters = 133 mm = 5.24 inches
length would be 40 * 6.9 millimeters = 276 mm = 10.87 inches
of course that size is impossible in real life, but this pack:
width: 162 mm (vs 153)
height: 150 mm (vs 133)
length: 276 mm (vs 276)
The length is EXACTLY the same as a naked foil pouch pack.
My measurement could have been off a few mm, and then there is tape and padding that could be a few mm (max) total.
Here is a KNOWN foil based pack:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=110380991991
Lau claims on there:
Dimension: 300 X150 X155mm
Weight: 10.3kg
The width is confusing as a naked 18650 pack would be
65 * 2 = 130 mm = 5.1 inches
The 30 mm gap could easily be the spacing for welds and glue
but that does seem excessive as that's over an inch, a great deal for separating just two halves of the pack.
The length of a naked 18650 (14 cells) would be
18 * 14 = 252 mm
Again a 25 mm or so gap. One inch. Still no help.
Height of a naked 18650 pack would be 8 * 18 = 144 mm = 5.7 inches
In this case 18650 would be a tight fit but still plausing with a 6 mm gap
Buried on Lau's outdated lifepo4.hk site for 18650 packs:
Dimension 145*265*150mm
Net Weight ≈10.0kg
So that's almost a square height and width that's similar to this pack but a little smaller.
The width is dead on, so no clues there, he also claims 22 pounds.
See my confusion? It's way too close to call.
Chart:
Code:
--- this foil 18650 hk ebay1 ebay2 pingV2
width 162 153 130 145 150 155 160
height 150 150 140 150 150 150 155
length 276 276 252 265 270 300 280
* foil + 18650 are "naked" cells packed right next to each other, theoretical minimums
* hk = what is claimed on lifepo4.hk for 18650 packs
* ebay1 = what was claimed on ebay listing, cell type unknown
* ebay2 = known foil pack on ebay
* pingV2 = same cells, same number of cells as this pack - supposedly
