needWheels
- Joined
- May 27, 2008
- Messages
- 481
No you don't understand - the charger does nothing, doesn't get warm, the lights never change, the fan doesn't spin high - even Mr. Lau confirmed the charger should bring the battery up to 56-59 volts. This is not the old chargers they used to use, several vendors including Cammy seem to use this new one. It does true 5A output supposedly, it should get at least warm.
If I plug it into the battery when it's 52 volts, the charger does not change the battery voltage even after a few hours. My SLA charger will bring the pack up to 55 volts within the same time. So the lifepo4 charger is certainly not working. At all.
ps. I've never gotten 3.4v after it settles, do you have a duct tape pack or shrink-wrap pack from him they are different
