Is it an e bike kit, or the EbikeKit trademark kit? If you bought the 9 contininet kit from EbikeKit, it can take 48v no problems with the same controller.
Most mid size direct drive motors have no problems running at 48v, so that's Aotema, 9 continent, crystalyte, golden motor, etc. In some cases controllers may be limited to 50v, but if the caps inside the controller that look like little cans say 63v on them, then the controller is likely to tolerate 48v, that is about 58-60v hot off the charger.
At any voltage up to 48v, the heat damage to motors is mostly from long steep hill climbs, or really really long full throttle rides. Above 48v, wattages can get to be enough to damage stuff faster.
