Philaphlous
- Joined
- Mar 28, 2017
- Messages
- 431
So here's a pic of my design... I think I wired it right...
My go-to is excel...lol
Explaining my idea. Each color, yellow, green, orange is a parallel series of 7 cells each. So for each bank, you have a total of 21 cells except for the last bank (or first) which is only 7 cells. The cells will be protected inbetween each bank so the connections don't touch and short out the battery. On second thought I may have the last (13) group of cells at the bottom since then I could solder it directly to the next set of cells for 7.4V total, if that makes sense. The number inside each color corresponds with the number of cells in series, for the BMS hookup. I'm not sure if you start the BMS 13 at the lowest total voltage or highest. I think BMS1 should be the 48V and BMS13 should be the first 3.7v bank.
Let me know if you guys see any fatal flaws...literally. ha. Should be getting 27 more cells today or tomorrow. Once I get everything charged up I'm going to discharge test each capacity and group the cells accordingly. I should have my B6 charger tomorrow or Friday.
The lottery is coming!!! I'm super excited to see what cells are in these laptop batteries. lol. Since the battery pack is going to be sooo big, the current draw per cell should be relatively low. This should hopefully keep the explosive power of 91 cells down to a moderate level..lol
Welp... Guess I got what I paid for. The first pack of Chinese cells were TS 18650 cells. They weighed in at 44g and I was unable to find any specs on them online. My best guess is they're 2000mAh cells from China obviously. The next set I found quite easily, 46g cells, FST18650-2000mAh. They were actually printed 2000mAh on them and both are dark blue wrap. Standard discharge current is 2C which would be around 4A which is right at my limit. Hopefully going to get to doing some real world discharge tests this weekend on the capacity. At $1.50/cell it's not a bad deal but its not overly good either with what I got... The second set I actually am not that disappointed about. I can find data sheets on them, they seem to weigh similar to that of a samsung cell and supposedly the capacity isn't bad also.
