4S LiFePO4 as a 12V system
Now i'm hunting a 12V BMS, 4S lifePo4 3.3v.
Not that they are hard to find. Don't want to buy something that will have a short life span. Don't need any advance features just something that will protect the battery from abuse from me.
Played with the idea of not using one. Now realize that a BMS should cut off current if one Cell group drops to low even if the battery shows that it is not drained. Don't want to over charge a Cell group either. Will not really depend on the BMS to balance them as don't like to charge to 100%.
Don't really want a high end smart BMS over a $100, something in the lower end that will detour disaster.
I'm watching the developments with "drain down" cell balancers. When a 14S lithium-Ion pack gets fully charged to 58.8V, a "dumb" charger would put one cell at 58.9V and another at 58.7V...and that's one of the reasons I charge to 90%, because of the variations in mass produced electronics.
So, I charge my 14S packs to 57.0V...and hopefully the BMS actively drains and charges the cells to the same voltage. A drain-down cell balancer simply drains the higher cells to the lower cells...or...drains the high cells to a resistor load.
4S LiFePO4 packs would be one of the first products that would sell well...
I plan to balance the cells, could get a balancer but need to tend to my trike first. It may get a cell balancer first. My home back up will get left overs. Thought about going with out a BMS, as I learn think both a BMS and cell balancer is needed is this over kill?
