I have a 52 volt 24 ah triangular battery that I purchased from Luna along with a BBSHD motor that i installed on a Jamis Durango II last spring and have been enjoying it to commute 50 miles to work and back for several months until it suddenly left me stranded at work on two occasions acting as though the battery was dead....only to find out later the battery was not dead, but was simply asleep and shut down. Three times now the battery seems to go to sleep when I set the charger to charge to 100% and it is apparently getting an overcharged cell and waiting to bleed down the voltage before I can use it. I have been able to jump start the battery the first time by just plugging it into the charger later hours after the shutdown and it sprang to life as though nothing was wrong. I have two chargers and have had it happen with both chargers when set to 100%. Unlikely the chargers are bad I am hoping it is only a setting in the BMS or at worst the BMS needs to be changed. Any input would be greatly appreciated until I hear back from LUNA I am not using the bike, as it is very cold and bad weather here in Maine I cannot chance on getting stranded by a sleeping battery. There is a small volt meter plugged into the pack that will let me know if the battery is awake or not so today it is asleep after getting charged up last night and I drove the E Car (Honda Clarity hybrid) to work instead. I will call home to have the better half check to see if it wakes up on its own or if it will need to be jump started. I could always only charge to 90% which will in the long term only increase the amount of charge cycles, but I only have one smart charger and will need a second unless I am going to babysit the battery while charging on the basic charger as I have the volt meter it is doable but the 2 times I let it go to 100% I got stranded so not a good plan as pedaling a 65 pound bicycle 25 miles with no help from the motor is more of a workout than I want!
