52v samsung too much
chbronco
Have a golden motors 3kw lc motor, with the gm victor 200 48 volt esc. Will the luna cycles 52v 25r 20ah be too much? Should I just go with the 48v?And will be running a cycle analyst v2.3
All depend of how much cost and how much top speed do you want. For a 48V ESC that voltage is ok. You don't really need 25R for a 20Ah battery if you are not going to push more than 40A continuous. You could use more capacity and less costs 10A also NCA cells like 29E or PF's.
