torqueboards
I've read quite a few of the posts on here regarding BMS systems on 12S, 24S, etc systems for Ebikes and attaching BMS systems to LiPo batteries. I'd like to see if I could add a BMS system to my 6S 25V Lipo Batteries. Couldn't find exactly what I needed. Need a few pointers on where I can look to learn more about how to wire the BMS system.
Currently, my system is strictly LiPo's - (2) 3S 5000mah Zippy Flightmax 30C in series. I run (2) 6374 Sk3 RC Motors on 6S. After a run they do become unbalanced by 0.1 - 0.8v usually it's 1 cell on each 3S pack. I end up running both of the batteries on a battery medic from HobbyKing to get the cells equally balanced. Once balanced I pop it onto my charger and charge multiple packs on a parallel charging adapter board. This method has been working great and batteries have lasted a ton of charges. However, I'd definitely like to explore the option of a BMS system and be able to charge directly to my board.
(1) I would like the option to switch batteries as I currently have (3) sets of (2) 3S 5000mah 30C Zippy Flightmax in series for 6S 5000mah. Would I be able to with a BMS?
(2) I want the batteries to balance themselves while in use.
(3) I want to be able to plug a charger in and charge batteries without a regular LiPo charger. How does the charging work when plugged in? Is there a button to flip or does it automatically charge? Is there an LED that lights up when charging and/or when fully charged? Does it auto turn off when it's fully charged?
(4) Can I install these rocket switches as an on/off button for my board itself? eBay List of Switches - http://www.ebay.com/sch/i.html?_trksid=p2050601.m570.l1313.TR0.TRC0.Xrocker+switch&_nkw=rocker+switch&_sacat=0&_from=R40
I know people have been recommending http://www.bestechpower.com/ for PCB/BMS boards. Are there any other places that are good too for PCB/BMS Boards?
Any links to any setups that could provide helpful info would be great through. I don't mind reading through posts as well. I just couldn't find anything I was specifically looking for.
