As part of a uni. project, I will be building the above mentioned battery pack. The battery is going to drive two motors. The motor controls can work with both voltages. I am now wondering which voltage to use and therefore seeking your help, thoughts and ideas.
The maximum power dissipation is gonna be 80 kW.
From checking what the big automotive companies use in the battery packs, the voltages that I have seen are max. 415 Volts and I am trying to understand why is that.
When comparing both voltages these are the points that I can think of:
*Higher voltage -> less current -> thinner wires
*Lower voltage -> more cells in parallel -> less resistance -> a bit more balanced pack
One of the reasons I am wondering about the voltage is the need of having dc-dc to have a low voltage system as well. I haven't found any 600 Vdc - 12 Vdc so far.
Any thoughts, comments, ideas will be appreciated.
