Will
When riding my 21 (7x3) speed Schwinn C-lyte 409 commuter, I mainly use 4th to start off, and progressively shift up to 6th to cruising (large front ring only). Occasionally, if I want a climbing gear, I'll stay in 4th and shift down to the mid-ring. I thought this was equal to staying on the big ring and downshifting 2 gears in the back because it was noticably easier to pedal. Recently I was directed to 'Sheldon Brown's' gear calculator page. I was surprised to learn that 4th gear mid-ring yielded 11.8mph just as 3rd gear big-ring yielded 11.8mph (@80 cadence) though the latter is noticeably more difficult to pedal. Equal speed yet different required effort. Apparent in this situation is how the chain drive lines up. The big ring lines up with 5/6th gears, the mid-ring with 4th gear, and the small ring with 3/2nd gears. If the big ring loses felt power transfer efficiency at 3rd gear, then what good is an 8 or 9 speed with only a single front ring? With a 7 speed, I would hope to never need to use 1st, and only occasionally use 7th gear (7speed) on down hills with minimal pedalling torque applied, but wouldn't an 8 speed, single front ring to 8 rear freewheel, be an ineffiecient addition of gearing? To me, seems crossing the chain, right side front ring with left side rear sproket, makes a BIG difference. What have others on this forum experienced with cross chain pedalling?
Oopps, my bad, I used standard gearing from a chart and my bike has unique gearing. So, 4th gear mid-ring = 11.6mph & 3rd gear big-ring = 13.1. Yet, excellent remarks made by forum members below are worth reading :?
