chooks42
New here
I bought recumbent trike 2nd hand in the mid 2000’s, and I loved it so much. I’m now 54, and want to set it up for the next half of my life. I live in Australia.
As it is now:
Pictures enclosed. (dusty from lack of use)
Obviously tech has increased hugely in this space. I need some advice. I’m very flexible and happy to throw money at it.
I chose this initial drivetrain setup because:
I never had this setup going properly, due to the business that I ran that ran me - if you know what I mean!, but in the testing it worked well - not quite enough top end gearing though. I changed the outer one way sprocket on the motor to the smallest possible - still not quite enough.
This is what I’m looking for:
Would love:
Use:
Questions:
There is a lot in this - Thanks in advance.
As it is now:
- Greenspeed X5 folder.
- 16” Wheels.
- Cyclone 500w motor from china (10 years old), set up as a mid drive underneath the seat (large gold chain). Apparently the specs are: motor is 80kv, gear ratio 9.33:1. 8 poles.
- Cyclone Controller (i think)
- Nuvinci 360 rear hub
- It has 3 ring gears - 52/42/30 (on first count) on the BB (hence the jockey wheel cage setup that I built near the motor- and also because the trike is a folder, I need that flexibility from the front chain)
- Gator Brakes
- Less stress on the full chain on a BB motor
- Cleaner to have motor underneath the seat, and there is room
- As its a 16” i don’t want the normal cassette derailer systems - its too close to the ground.
- I prefer mid motors and the gearing on the hub rather than hub motor - but am open to other suggestions
- Pedalec with torque sensor
- Ok with Top Speed of around 40-50 km/hr. Any more on this, and it's uncomfortable.
- Good computer
- Brake sensors
- 500-1500 watt motor
- Light as possible
- Don’t need as many gears as without the motor
- I’m not attached to the Nuvinci
- Less wires the better
Would love:
- Electronic shifting
- Prefer hub gearbox at this stage, though recognise that tech is getting better with hub motors
- Am loving the gearbox /motor units that are on the horizon (Intradrive etc). Not available yet, I believe
- Reverse gear
- Walking mode or starting with torque settings like the CYC motors
- DC- DC converter (to run lights etc on system battery)
- A rear belt drive (with the required frame modification). Anyone tried this?
- To add fairings one day.
- Potentially add solar panels for long distance touring
Use:
- Daily ride
- To do some longer camping trips / touring
Questions:
- Would a BB motor and large chain handle the length of a recumbent chain?
- If so, then a BB motor (like CYC?)
- gears
- Is there a gearbox available that I could use in the place of the mid motor?
- Nuvinci probably doesn't have the ability to handle the power?
- rohloff? (don’t really need 18 gears???)
- Other internal hub gearbox
- Motor / gearboxes like Intradrive - they seem awesome - not available yet but Any comments?
- Chainwheel
- Mountain drive?
- Modify it to a 2 or single chain wheel?
- Have hub motors increased in quality to make them an option? Which one?
- FreeGen from GRiN looks amazing! Would that work in any setup?
- The Gator brakes.
- They have never been good and they look to be out of business.
- Can I still buy pads for them?
- Or should I look at replacing the brake calipers? Suggestions?
- Or hub brakes?
- Should I abandon this project, sell it and buy a newer recumbent that's more suited to what I like. Greenspeed was the ‘rolls royce’ of recumbents. I’m obviously happy to spend some coin on this and am a mechanic so can do the work.
