7005 aluminum
t_tberg
Pittsburgh, PA
I'm starting my third build on an '05 Kona Dawg, this is the first time I'm using an aluminum frame. I believe the swing arm is the same material as the rest of the frame (7005 aluminum). Ideally I would like to get some custom torque plates made, does anyone know what the cost of something like this will be? The dropouts look to be 6-7mm, I may just use grins v4 torque arms since I already have one. Peak power will be about 2500w (20s). Has anyone used the '05 kona dawg with a hub motor or 7005 aluminum in general, what were your results?
With that configuration why not put torque arms on both sides?
20160222_180328-min.jpegThe plan as of right now is to try to build some steel torque plates that would pinch the dropout between the plate and some kind of backing. Here is a quick sketch of what I'm thinking.
From the photo it looks like the brake calliper mounts are in the same plane as the outside of the dropout slot, so I would make a torque arm from steel plate that picked up on the nearest calliper screw (or both screws if you're running a lot of power). There's plenty of room below the dropout slot for a cross-bolt to make the arm of the clamping variety. Ideally you'd have a similar arm on the opposite dropout, but if your power level is modest then single-sided solution is viable.
7005 aluminum is fairly ordinary stuff that's comparable to 6061 alloy, the industry standard structural aluminum. In bike frames it has the unique benefit of allowing manufacturers to skip the solution heat treatment step of the hardening process, because in bike tube sizes it does that by itself at air cooling rates after welding.
Do not rely on any aluminum alloy to restrain motor torque applied through flats on a steel axle. The steel will always prevail.
