Hi,
I am planning my next build, 3000 watt hub motor, 150 amp controller ,
Do I need to find high discharge rate batteries with a 150 amp BMS, ???
My current bike has a 3000 watt hub motor, 72 volt system, 80 amp controller and I am topping out at ONLY 70 KPH, On 26" wheels.
My batteries are generic with no info. ( 6x 36V) each pack with it's own BMS.)
I had to put in a battery cut-of switch as I was losing 1.5 volts a day when switched off, Now it works fine with minimal discharge.
So I am looking for a higher top speed, A 150 amp controller will help, I am not sure on the batteries,?? This time I want to go with a pre-built pack, Rather than wiring my own packs, So are there battery packs with a 150 amp BMS OR am I out to lunch with my thinking,??
