whatever
- Joined
- Jun 3, 2010
- Messages
- 1,297
I recently had a power blackout for a week or so, I needed to use my a123 20ahr cells to power lights etc.
The cells were I think produced in about 2006 or 2007, korean a123 20ahr.
Unfortunately some of the cells went 'soft' during use ( the soft cells were all about 2.9v after use). My first reaction was, these cells are buggered, may as well throw them out, but I decided to try to recharge them. Interestingly the cells after recharge went back to a 'hard' state, there was no compression on the cells when being used for lights etc. The cells appeared to still have a reasonable ahr capacity.
To recharge them I started with a few hours on 500mA, then quite a few hours on 1amp, then the rest of the time to fully charged on 2amp.
I have not discharged the 'soft' cells since recharging them, I will put them under compression first otherwise i think they will go back to the soft state. I will post results with a view to seeing if the cells are in fact still useable at least for low amperage applications.
