A2B 5 pin rear battery connector ?
Hillhater
100 TW
Sydney ..(Hilly part !) .. Australia/ Down under !
I have tried multiple searches on here and the net to no result.
But i am sure i have seen posted a make and source for these 5pin , screw lock, battery connectors used by A2B for their rear battery packs.
Any hints ?
The yellow female socket...about 15mm dia.
Its a 5/6 pin waterproof connector with a stainless screw collar to lock it together.
It is very like a 6 pin XLR, but i dont know if the size is a match or if they can be supplied with the screw collar.
The closest visual i have found is this GT1-4880 jack.
http://www.cnglobaltone.com/productdetails.asp?productID=10041
M23 type may be the closest match:
Chasis socket
https://attend.manufacturer.globalsources.com/si/6008814768084/pdtl/Plastic-circular/1164097834/M23-Connector.htm?state_filt=CN_CNFUJ??source=CE_Xpromo_PopPP
Piggy plug:
https://datainterfaces.com/cab-m23f5-open-industrial-ip67-m23-5-pin-threaded-amphenol-connector-for-power-itp-switches-with-open-end-cable-1m/
hope this helps a bit :wink:
