rhubarb
1 W
I'm running a KMX kart with a Puma Motor and two 28V LiPOs.
I'm using a 20" wheel (unlike Knoxies and others which use 24") and there's no pedals or chain.
I've been using Crystallite 20A / 48V controllers which have IRF 2807 FETS rated 75V / 82A. These have been failing fairly often!
I decided to upgrade to higher voltage controller, the large cased crystallite 20A 72V. I had a couple of these a while ago and they had 12 FETs.
I hoooked it up and tried it out. It worked fine at 56V, but when I couldn't help myself and hooked up a third LiPO (=84V) it went like a rocket out the driveway and 50 meters up the road and then went phut.
Cursing, I opened the case up to discover that the new controller has the same board as my lower voltage controllers, only the Capacitors are rated 200V and the FETs are FB4710's (rated 100V, 75A).
A pair of FETs were blown.
Help! Why am I blowing so many controllers, and what should I be doing if I want to run my KMX on 84V reliably?
Can I still get a crystallite controller with 12 FETs or have they gone for a cheaper spec?
thanks! Help me in my quest to join the 40mph club!
