d3drturner
New here
- Joined
- Apr 14, 2019
- Messages
- 23
Accelerated Systems BAC500
running SYXD01F Bafang front wheel drive
with Thun X-Cell RT Digital 120k/116mm
and 12S 2P battery that shows 49volts having some proprietary BMS
and a 3 setting switch with off, low, high that has an "e-ink" display that does not appear to work
With the battery plugged in, the controller lights up as normal but the motor is not activated.
I have the BAC software called BacDoor but I can't find the RxTx lines nor do I know how the diagnostic cable is constructed.
And I created a problem while removing the torque sensor; the wires that were spliced together to the connector came apart; the colors are mostly different so it's not clear how they should be reattached (the connector wires are RGBYBlack; sensor wires are Black White Grey Brown Blue):
I hate to scrap the system and replace it all with vesc but I am at a dead end.
Any ideas?
Any ideas?
