Lectriceye
⚡ Regular
I confess that I am a newby with a strong electronic background. I have a very good 1000w hub drive ebike with a 48 volt 21ah battery. I don't care about speed and usually motor around on PAS 2 of 5 going about 12 mph pedaling with a cadence of about 70-75 RPMs, which is plenty fast most of the time. I like to go distances of 25-40 miles, and I ride a lot of forest service roads which often times have inclines in excess of 5% that can run 4 or more miles. In the last 3 months I have burned out 2 controllers on those long hills and I am coming to the conclusion that I purchased the wrong bike for my kind of riding. Without getting into a lot of detail about the circumstances of the demise of the controllers, I will say that I have ran the simulations and can see how and why they were zapped by too much current and the ensuing heat. Power is my friend heat is my enemy. Thus, I am now contemplating going to a mid-drive that gives me the advantage of combining the power of the motor with the gears of a mountain bike. I ran the simulation of a bafang BBS02B 750w on the same bike, and it indicated that I could ride any of those long hills up to 9-10% without running out of gas/juice. Using what little knowledge I gained in the last few months, I would like to add the BBS02B to my existing bike, which would be the most economical approach, I can get the get from Amazon for about $450 and do the work myself. I don't care if they run together or seprately and independantly. I have 2 batteries currently in use on my ebike with a blender, and a switch to turn them on or off as desired. they are there primarily for extended range. The downtube OEM battery is 48v 21ah with 30A BMS. the second battery is 52v 20ah with 40a BMS. Using both together is how I blew my second controller, obvious to me now, that I had about 40 amps available to my controller going up that 4 mile 7% grade.
So, the real question I have when running them separately, at different times, with the mid-drive switched off, what happens to the bub drive pedal assist? I need help from someone with more experience here.
