drmacgyver
- Joined
- Mar 29, 2014
- Messages
- 189
I need some advice on how to connect two of these in series: ZIPPY Flightmax 8000mAh 3S1P 30C
Should I swap the pre-soldered 5.5mm bullets to something different, or keep those and design my series connector around the 5.5mm's?
Using a HK 150a car ESC with 10awg wire. I added 4mm bullets in housing to match the 4mm's on my 6s 5000mah, which is obviously being replaced.
This is my charger: IMAX B6-AC Charger/Discharger 1-6 Cells
