I've just bought the following to build an EV motorcycle or Japanese low rider scoot of my own design.
I have no issue with designing/ building the actual bike/mechanical stuff but could do with some pointers on the EV element..
My EV kit;
QS 12inch 10kw 96v Hub motor V4
Fardriver controller ND961200
96V speedo / battery display
96v-12v inverter
Twist throttle
Brake disc kit frt and rear
Are there circuit diagrams out there that would help me?
Also before I go to the very big expenditure of the battery (likely 26S21P using Molicel42A's) is there a way for me to bench test the kit with say a 96V off the shelf battery to ensure all will work?
BMS's, I was looking at a 300A via AliExpress..
What else do I need to consider?
My EV kit;
96v-12v inverter
Twist throttle
