tuxman
Before I bought my GT Charger electric bicycle from Sam at electroportal a few years ago, I did a bit of research, and found several different types of ebikes.
The GT Charger was very attractive mainly because the motor drives the Shimano Nexus-7 transmission and it's price point complete. Also, I didn't want a kit with bugs to sort out. It was purpose built and well designed. Made in the USA. Powerful. http://www.electric-bikes.com/bikes/charger.html
I am very happy with my Gt Charger at over a thousand miles on the bike. After my controller stopped working, I fitted an aftermarket Curtis 1505 controller, potentiometer, on/off switch and battery charger using the stock battery pack. Not as clean looking, no longer vintage, but it's much more powerful than stock. Wired the headlight directly into the battery pack this time around.
After I set the throttle using the potentiometer, I leave it, then turn the power on/off at the push of a button. This allows me to fine tune the power of the motor to match my cadence. On the flip side, you have to peddle any time the motor is on. Being pedelectric I had to peddle to turn the motor on before these mods so this was nothing new.
I don't have a way to monitor the amp draw other than by the fuses I've blown. Was using the stock 20 amp fuse but quickly found out the new controller was much more powerful. 30 amps was fine for awhile, but it blew when I pushed too hard on a major hill in a higher gear than usual. Went to a 40 amp fuse and haven't blown one since.
My commute is 5 miles one way, 4% mean grade of rolling hills. With the 14ah SLA battery pack, an average 25ah draw, using the motor assist on every hill, it has been more than enough to make the commute. Have had 2 flats, blown fuses, chain pop off, but have not had the battery pack go flat in all these years.
I am happy putting the power to the peddle with my Gt Charger!
