pwd said:
minde28383 said:
If you will get fast winding your will have less dynamic ride than you would have with 5T or 6T.
If you get slow motor 5t or 6t you will get better dynamic with you weak battery.
As far as I understand and having read though the "myth" crushing threads; a faster wind or low turn count doesn't demand more current from the battery pack. It demands more phase current from the controller; which is done with the same input (battery) power.
Nop, because one lives in material world with predetermined conditions like readily available controllers, popular battery voltages.
These myth busters never tried any of these motors but have pencil and paper and few physics books.
by post edit I extend myself little bit more. What I mean by 'predetermined'. We have readily available controllers and they perform as they do perform and result is that slower motor is more dynamic in slower speeds. Vast majority is using Sabvoton and Kelly with 3kw hubs. We are talking about 350a and 300a phase.
Also worth mentioning that battery amps is also the factor, not only phase current as you mentioned. Talking about slow speeds and starting from stand still. With fast wound motor you draw more amps from battery because you set more amps on your controller to achieve the same expected performance from stand still.
