JCG
- Joined
- Nov 10, 2008
- Messages
- 174
Hi all, I have a fast and possibly easy (and at the moment hypothetical) question regarding charging sealed lead-acid (or AGM) batteries.
Suppose that you have a system that requires 96-108 VDC or so, and you use eight (identical) 12 V AGM batteries in series to provide it. Now, also suppose that you have on hand a DC power supply that provides exactly 108 V. Would you feel safe charging the AGMs (still connected in series) with this power supply over a long time period? The 108 V would correspond to 13.5 V per battery, or 2.25 V per internal cell (2.25 V is the "standby charge voltage" or "float charge" per cell that I've seen on the AGMs I own). I've read that you can apply a float charge indefinitely.
I know it's best to just charge them all in parallel at 13.5 V instead, but if you had a high voltage DC power supply, could you use it on a series-connected bank without ruining something? You would never try this with any other chemistry, I'd bet; but maybe with AGM it's possible. Thanks in advance for any advice.
