aide
morriss18
10 µW
Drummondville
bonjour à tous j'ai un problème avec mon moteur depuis un moment maintenant il a démarré du jour au lendemain le contrôleur et l'afficheur sont neufs j'ai refait tout mon câblage je ne sais pas quoi chercher pour trouver le problème
Solution
google translated hello everyone I have had a problem with my motor for a while now it started overnight the controller and display are new I redid all my wiring I don't know what to look for to find the problem
Should I list all the possible problems with motors that can happen and you tell me when I get the right one? ;)
Then I could list all the possible motors and systems and you can tell me when I get hte right one of those.
It will take a long time to do, but if we dont'...
It will take a long time to do, but if we dont' know at least those things it's going to be difficult to help you.
Optionally, you could tell us exactly what problem you are having, exactly what happened just before the problem began, 1and exactly what system (motor, controller, display, battery, etc) you've got, it would be a start to get enough information to begin helping you.
It would also help us to know whether the problem existed *before* you got your new controller and display, or *after*, and also if it existed *before* you redid your wiring, or *after*.
If it's a wiring problem, it would also help to know what your wiring was *before* the problem started, and what it is now. (every wire, which wire went where before, and which wire goes where now. I highly recommend you draw up a complete wiring diagram of every single wire (not just cables but the wires that are in them) both for us to help you troubleshoot, and so you will have it later on when other problems happen.
Solution
Please just tell us in words, as clearly as possible, all of the information that's been asked for.
I don't know about anyone else, but I am not going to spend time watching a video and guess what it's trying to show me, then post what I think it's trying to show, then wait for your answer or next bit of info, in order to figure out what you need.
