Reid Welch
Please click this link to see many more and varied videos:
http://www.stirlingengine.co.uk/ks80-solar-low-temperature-stirling-engine-456-p.asp
Here's the one I owned, and ran for over a year non-stop, under a glass dust-protection dome:
[youtube]ldN1xdS3iRA[/youtube]
It would run as slow as 40 rpm, or ten times faster. I like slower, myself.
___________________________
Would like to get another Kontax, but of another style, this new model,
the KS80, is only a bit over $100US, delivered, fast, direct from the maker, worldwide.
It is reliably claimed (I know the maker) to operate even "better" , being a "solar" powered machine.
Pure, forever-motion afforded by the light of a lamp or the sun, or on a cool counter top, or warm hand.
It's on my wish list. Hundred bucks. I like the new, clear spoke design and -no- brass pillars to tarnish from touching.
It is minimalism to the max. All C&C machined to the n'th degree of accuracy, both in the parts and the packing and instructions included.
Scale one up and make a solarbike? :wink:
Of course, the LTD Stirling in this size produces only a modicum of power;
enough to spin very slow, or up to about four hundred rpm (a guess)
Don't put one on the stovetop, OK? You'd melt the foam displacer, if not the polycarbonate base.
Even more the plus side, the Kontax models do not ever wear, nor need any lubrication.
For best results long term running (like for a century),
just keep the unit free from dust.
But, it will run in the open for years, with, at most, a wipe-off of the power piston,
easily removed by detaching one screw.
An optional glass dome and brass base that I sourced (discovered) for the makers (am not affiliated except as a friend),
is now available from them; a perfect fit and perfect protection for your LTD Kontax brand Stirling.
Things that tick and tock are fun to watch. This engine makes NO sound at all.
You can set it atop your computer or router to run it indefinitely.
It's very Zen-like, especially under glass.
A year ago I gave this unit to my charity MD as a gift of gratitude.reidsteam
December 06, 2007
Kit-assembled, Kontax KS90, running slowly for clarity of operation.
Please notice that the displacer, that white disk, has plenty clearance from the wall of the big, clear, "displacer" cylinder.
The displacer is passive; it simply stirs, moves, air from one plate-side of the container, warm here,
to the other plate, the top plate, cooler there, atop...making, thereby, an alternation of contained air =pressure=,
by which to push upon, and then "suck" upon, the tiny, power piston.
Its flywheel's two metal-sheilded (not sealed) ball bearings bear NO lubricant,
other than that which comes from atmospheric-borne 'film'.
So, the pressure in the displacer chamber alternates from high to low,
sufficiently-so, to make push and pull upon the closely-fitted,
frictionless, non-wearing, graphite power piston,
running at micron-clearance in a borosilicate, glass cylinder.
It would run for a century, if kept fed with "caloric".
It runs on ice, opposite direction, or it can run on the heat of a warm hand,
if the room air is cool.
Please notice that the displacer, which has plenty clearance from the big cylinder,
simply stirs, moves, smooshes, the air from the warmer deck to the cooler deck.
In this way the air in the displacer chamber is alternately heated and cooled.
So the pressure in the displacer chamber alternates from high to low,
sufficiently to make push and pull on the closely-fitted, frictionless, graphite power piston.
Thank you for rating,
Reid Welch
