flippy
- Joined
- Aug 12, 2015
- Messages
- 2,351
i am sorry, but you are not making any sense.eMark said:My definition of "stand alone" is that ... https://pt.aliexpress.com/item/4000529723243.html ... doesn't provide true "active charge" like that of a dc balance charger or analogy of a traditional 12v dc voltage regulator, alternator, etc (car BMS).
its not misleading in the slightest. its just the standard chinglish auto translator. you have to re-convert into your head back into normal english yourself.eMark said:To say the aliexpress is an "active charge" BMS is a little misleading as it's more of a voltage equalizer ... more so than an "active Charger" between the p-groups. Similar comparison is the following equalizer analogy ...
eMark said:An analogy would be several small inter-connected fish pools in need of maintenance that slowly leak at different rates. The pools that leak the least will provide water to the pools leaking more thus hopefully maintaining all the pools at the same level ... wouldn't consider that an "active charge" compared to the pools being periodically "charged" by a spring to prevent them from all going empty.
that bms can be programmed to continously balance the pack if you wanted to. but you should not. you only balance during the end of the charging process and continue until fully balanced. that is also why you need high balacing current in the battery that is being made here.
2 things to rectify in this:eMark said:... https://pt.aliexpress.com/item/4000529723243.html ... is certainly a welcome improvement over traditional discharge BMSs that for the most part are pathetic being more of a BPS at best than a BMS. That Ali BMS is an active leveling equalizer. By active i take that to mean that this Ali Smart BMS is constantly active :thumb: meaning it doesn't wait until the charged battery pack is close to FULL before balancing the p-groups via resistance discharge drain.
1: "active leveling equalizer" is not a thing.
2: its not smart or "active", its programmable.
please dont see my comments are agressive, i am just to the point. i only want everyone to use the same terms so everyone talks about the same thing and does not confuse anyone else.
